Use this function to calculate the area formed by the lines selected and insert the same as a text label.
MOUS_ICO Menu: Landscape > Annotation > Area Label by selecting LinesMOUS_ICO Toolbar: Annotation: Area Label by selecting Lines
Command prompts for: Pick a line, arc, or polyline: Select all the entities that define the area and finish with the 'right button of the mouse or the key 'Return'. Tip: * All object selection methods that are available with AutoCAD can be used.
