Use this function to annotate a selected object (area) with its area.
MOUS_ICO Menu: Landscape > Annotation > Area Label on defined AreaMOUS_ICO Toolbar: Annotation: Area Label on defined Area
Command prompts for:
Pick area:
Select the area, for which area label is to be inserted.
Pick text position:
Pick the insertion point for the text label.
Tip: * The 'Drawing Scale' (Novapoint Base function) settings will reflect this function.
