Big Sheet - US Feet - Cross Sections.vcl
05-01-2019 16:39
This file is a Drafting Template that draws all of your Cross Sections on a single "Big Sheet" (1000" x 100" in Landscape Format) so that you can then select the Sections in one step and export to AutoCAD DWG / DXF Format etc. rather than sending a number of Sheets to AutoCAD DWG File. This emulates what Bentley and Civil 3D do to create Cross Sections in the Model Space View (Without automated sheet layout which is of course easy to do in TBC ...)
Download the file and place it in your Drafting Templates Folder.
The Drafting Template is in US Feet and creates Cross Sections using the Individual Sections With Grids Style.
Hope this is helpful.
1 Files
13 Downloads
Attachment(s)
zip file
Big Sheet - US Feet - Cross Sections.vcl.zip   43 KB   1 version
Uploaded - 11-18-2020
05-03-2019 08:27
I do not recommend that you use this approach (or at least this paper size) to output to PDF format. Acrobat Reader at least really does not like these Big Sheets.
