The function constructs a bus stop based on selected parameters and a baseline in the drawing.
MOUS_ICO
Menu: Landscape > Construct Lines and Polygons > Bus Stop
MOUS_ICO
Toolbar: Construct Lines and Polygons:
Bus Stop
When starting the function, you are first asked to pick the baseline. Pick baseline: Select a line, arc, or polyline in the drawing.
The dialog box appears with the parameters that define the bus stop. All parameters are in meters:
A - Baseline W - Width L1 - Expansion, St L2 - Invariable, Lm L3 - Constriction, Sl
Chainage: This is the insertion point of the bus stop (where you picked the baseline). The chainage is calculated as the distance from the start of the baseline to the point where you picked thebaseline. You can also type in the chainage.
Move: Function to move the bus stop along the selected baseline by moving the cursor along the baseline. Press the left mouse button to place it. Press 'OK' to draw the bus stop.
