Novapoint Landscape Library
Change to Point Elevation Retained
04-08-2021 06:35
Use this tool to set underline to one or more point elevations.
MOUS_ICO Menu: Landscape > Elevation tools - drawing > Change to point elevation retained
MOUS_ICO Toolbar: Landscape II: Change to point elevation retained
Working procedure
Start the function and the command prompts:
Select object:
Select the point elevation object(s) that are to get an underline. When finish, press 'Enter' and the selected point elevation objects will get an underline.
About point elevations in Novapoint Landscape
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
