Novapoint Landscape Library
Change Type of Area
04-08-2021 08:39
This function will allow you to redefine areal type, properties, and descriptions in the drawing.
MOUS_ICO Menu: Landscape > Land use disposal >Change type of area
MOUS_ICO Toolbar: Land use disposal:Change type of area
When starting the function, one or several areas may be selected.
Select objects: pick the hatch or description - the dialogue 'Define areal' appears.
Select new areal type. The dialogue appears.
Type description, press OK.
Pick annotation point: set out annotation
If several areas were selected the process will be repeated. Land use areas will then be created in the drawing.
