The function 'Check Point Elevations' checks all elevation points in the drawing and ensures that the height is consistent (text value = true z-value). If errors are found, the point elevations that are faulty that have to be edited will be marked with the color magenta. It will also be written in the command line:
[X]faulty point elevations were found. They are marked in red.
MOUS_ICO Menu: Landscape > Elevation tools > Check point elevations…MOUS_ICO Toolbar: Elevation tools – Check point elevations…
