Use this command to draw hatches for all the areas defined by Land use texts and lines with topology features.
MOUS_ICO Menu: Landscape > Land use disposal > Connect All Text with Borders, AutomaticallyMOUS_ICO Toolbar: Land use disposal: Connect All Text with Borders, Automatically
In Novapoint Landscape, areas are defined by land use texts and lines with topology features line library marked [T]. The hatches are drawn by connecting the lines and Land Use Texts.
When the function is started the dialog 'Set Active Plan' is displayed - press OK. (this defines the Area Drawing Rules to be used when making the hatches, choose 'Landscape Design plan version ##.## with color' corresponding to your version of Novapoint.
All areas will be built.
If you run into problems connecting the areas read areas_troubleshooting.
