This function lets you make areas from selected Land use texts by using the “smart”-lines(lines with topology features from the line library marked [T]).
MOUS_ICO Menu: Landscape > Land use disposal > Connect Text with Borders, AutomaticallyMOUS_ICO Toolbar: Land use disposal: Connect Text with Borders, Automatically
When the function has started, the dialog 'Set active plan' will be displayed. It defines the set of Drawing Rules to be used. In Landscape, you usually use the 'Landscape Design plan version ##.## with color corresponding to your version of the program. Press 'OK'!
'Select objects' - Pick one or more Land use texts, Press <enter> and the areas are drawn with the corresponding Area Drawing Rules (hatches) and can be quantified by using the function Search for Land Use in Drawing.
'Select objects
