Use this tool to copy point elevations and slopes within the same drawing. Note that the AutoCAD command 'copy' does not work on point elevations!
MOUS_ICO Menu: Landscape > Elevation tools - drawing > Copy point elevationsMOUS_ICO Toolbar: Landscape II: Copy point elevations
Start the function and the command prompts:
Select object:
Select the point elevation object(s) to copy. When finish, press 'Enter.'
The command prompts:
Specify base point or [Displacement/mOde] <Displacement>:
Select the base point of displacement. Select the place to copy the point elevation object(s). When finish copying, press 'Enter' to exit.
