Novapoint Landscape Library
Copyclip Point Elevations...
04-08-2021 06:37
Use this tool to copyclip point elevations and slopes from one drawing to another drawing. In order to paste - use the function Pasteclip point elevations. Note that the AutoCAD command 'copyclip' does not work on point elevations!
MOUS_ICO Menu: Landscape > Elevation tools - drawing > Copyclip point elevations
MOUS_ICO Toolbar: Landscape II: Copyclip point elevations
Working procedure
Start the function and the command prompts:
Select point elevations to copy:
Select the point elevation object(s) that are to be copied to another drawing. When finished, press 'Enter'.
Open the drawing where you want to copy the elevation object(s) to. Use the function Pasteclip point elevations and choose a position for the copied elevation object(s).
About point elevations in Novapoint Landscape
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations.
