This tool removes all properties on lines that were drawn with the !!line library!!. Both quantity descriptions and topology features are removed. These lines will no longer define the areas when using the function Land Use Disposal or be included in the Quantities.
MOUS_ICO Menu: Landscape > Lines>Delete Line PropertiesMOUS_ICO Toolbar: Lines> Line Properties
When the function is run the user is prompted to select the lines to be purged. All AutoCAD XDATA will be removed from these lines.
