Novapoint Landscape Library
Disconnect All Land Use Areas
04-08-2021 08:50
Use this command to disconnect all land use areas. All hatches are removed and the land use text and topology lines are left in the drawing.
MOUS_ICO Menu: Landscape > Land use disposal >  Disconnect All Land Use Areas
MOUS_ICO Toolbar: Land use disposal:  Disconnect All Land Use Areas
Use this function when you want to edit lines in the drawing. The hatches are removed so that you easily can edit the lines. The areas can be reconnected automatically again after editing the lines.
