Novapoint Landscape Library
Draw Centerline
04-08-2021 12:32
Use this function to change the appearance of selected AutoCAD lines or Novapoint objects to a desired drawing setup for centerline (pre-defined or user-defined).
MOUS_ICO Menu: Landscape > Lines Draw Centerline…
MOUS_ICO Toolbar: Lines> Draw Centerline…
When the command is started the dialog box 'Draw Horizontal Alignments' will pop up. You have three options to select input to make the centerline:
  • 'Object'
  • 'Pick from Drawing'
  • 'File'
Object
Use this option to select alignment(s) from the active digital terrain model (database).
Select desired objects to be drawn from the dialog 'Quadri Line Identities' and click 'OK'.
Multiple alignments can be selected by holding the 'Shift' or 'Ctrl' keys.
Pick from Current Drawing
Use this option to select the alignment(s) from the current drawing.
Click the option and follow the command prompt. Confirm the selection using key 'Return'.
Use the standard AutoCAD selection procedures for selecting multiple alignments.
File
Use this option to select alignment(s) available in ASCII file formats (*.TIT, *.LIN, *.LI, *.INH, and *.DAT).
The dialog box 'Select TenTable' will pop up. Select the file format at the field 'File of Type', browse to the desired file, and click 'Open'.
After you have made the line with one of the options above, the line is drawn.
Select the configuration from the pull-down menu to change the appearance of the line and click 'OK'.
Use the button to see more alignment definitions and to customize the pull-down menu.
To edit and create user-defined alignment styles use the shortcut to activate the Drawing Style Editor tool.
Tips & Notes
  • All object selection methods that are available with AutoCAD can be used.
  • The selected configuration remains current for other tools until the configuration is changed.
  • The AutoCAD entities will be erased.
Read more about alignment design in the help files for alignment in the Road module.
