This function draws a grid based on parameters for the length and width of the grid.
MOUS_ICO Menu: Landscape > Construct Lines and Polygons > Draw GridMOUS_ICO Toolbar: Construct Lines and Polygons: Draw Grid
Cell length <3.00> : KEYB_ICO Type in length in meters and press enter Cell width <1.50> : KEYB_ICOType in width in meters and press enter Pick lower left corner [Continue/Undo] MOUS_ICO Pick a point in the drawing (you can also use snap functions) Pick lower right corner [Continue/Undo] MOUS_ICO Pick a point in the drawing (you can also use snap functions) Pick upper right corner [Continue/Undo] MOUS_ICO Pick a point in the drawing (you can also use snap functions) Draw ? Yes/<No> : KEYB_ICO Make your selection.
Cell width <1.50> :
Draw ? Yes/<No> :
The function will draw a preview of the grid and you need to type Yes in order to draw the grid as lines in the drawing.
Tip: This function is very useful in drawing parking spaced for vehicles.
