Drawing rules are used to specify how to draw the slope calculation and have two sets of parameters:
You can define the layer and color for each of the elements in the slope calculation.
The Draw Column: All elements marked with an X will be drawn on a specified layer and with a specified color. Point in the square to set the drawing the element inactive.
The Layer Name Column: The function suggests a layer for each element. Users can type in the layer name they want to use. If the layer doesn’t exist in the AutoCAD drawing, the layer will be created.
The Color Column: The function suggests a color for each element. You can change the color by point in the Color field. AutoCAD’s standard dialog box for color will then appear and the user can select the color they want.
These parameters set up the drawing of the slope marking for the slopes.
Type: There are two different types available:
