This command will export a complete set of drawing rules in a text file. This is useful to retain custom drawing rules when reinstalling Novapoint, or when you want to move custom drawing rules to another installation.
MOUS_ICO Menu: Landscape > Setup > Export Drawing Rules for Surfaces
When the function is started, a dialog opens where you can select the name of the set of drawing rules to be exported. After you make a selection, a file dialog opens. Type a file name, and save the export file.
Land use disposal in Novapoint Landscape uses the Area Drawing Rules to visualize the Area Attributes as hatches in the AutoCAD-drawing. These drawing rules can be imported from a text file.
