WorksManager
FAQs: Field to Office
06-11-2020 19:37
  • Does WorksManager support bringing measured points back from Earthworks to WorksManager? Yes, you can view, & download recorded points from Earthworks in WorksManager. Navigate to the project devices -> select the specific EW device -> click 'Field data' link from the info. panel on the right.
  • Where can I access the field data (recorded points - .csv) of GCS machines for archived designs? In the archived state, you can access recorded points from TCC in the 'Archived' folder. Here is the path: Trimble Synchronizer Data -> <device folder> -> Archived -> <Project name>-<Design name> -> recorded points.csv.
  • Where can we download TAG files and how will this be supported in WorksManager? Raw TAG files from GCS900 machines are not available in WorksManager for download (its available in TCC though). Earthworks tag files are not directly available to customers. You can purchase WorksOS to gain meaningful insights from the as built/ TAG files
  • Does WorksManager support management of machine configuration files (.mch, .dsp, etc)?  For example, when the bucket of an excavator is changed and the updated machine (.mch ) file is also to be used on a different CB460, can WM send/get that file? The feature is in progress, and should be available by July 2022 for GCS, and Earthworks.
  • Are you able to share work orders and projects to another handheld through WorksManager? Not yet.
