File Flipper v1.3 Download
09-23-2019 10:27
Here is the File Flipper v1.3 download.
1 Files
285 Downloads
Attachment(s)
zip file
Trimble.CEC.FileFlipper.Setup.1.3.0.20190116121435 (1).ms....zip   14.99 MB   1 version
Uploaded - 11-18-2020
03-16-2026 14:43
Hi, is there any documentation for using File Flipper from the command line? running the exe with the flag "--help" exposes a list of other flags but nothing i try works.
01-10-2020 09:19
For some reason last time I hunt down the TTM exporter in the Export tool, I did not see it on the list.
But I see it now that you pointed it out. I should be good now then as far as that goes.
Thanks.
01-08-2020 14:52
Flipper will create a TTM from a LandXML or from a DXF / DWG 3D Faces File but I would just use Export and select TTM option in TBC to do this
Sent from my iPhone
01-08-2020 14:29
You can export a TTM from TBC using file export
Sent from my iPhone
01-08-2020 12:50
Alan,
Is there a way to produce a TTM file using the File Flipper? I am looking for a way to export a TTM file without creating a job site design. And this TTM file is really for me to upload to Trimble WorksManager.
