Novapoint Landscape Library
Insert Prefix to Point Elevation
04-08-2021 08:22
Use this tool to add a prefix to point elevation.
MOUS_ICO Menu: Landscape > Elevation tools - drawing > Insert prefix to point elevation
MOUS_ICO Toolbar: Landscape II: Insert prefix to point elevation
Working procedure
Start the function and the command prompts:
Select point elevations:
Select the point elevation object(s) that are to get a prefix. When finish, press 'Enter'.
The command prompts:
Enter prefix:
Type the prefix and press 'Enter'. The typed prefix will be included for all the selected point elevations
About point elevations in Novapoint Landscape
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations.
