Mass Haul Training Program
06-29-2018 09:09
The enclosed zip file is the Mass Haul training program that I deliver to classes. It is up to date on version 4.11 of BC-HCE. In each Exercise folder you will find Start Point and Step Point Project Files and End Game Projects. In Each Exercise folder you will find a Step by Step guide in the form of a Word Document that you can follow along with the sample projects to learn how Mass haul works.
The examples are all schematic - all designed to teach you the basics of Mass Haul so you really understand how the calculations work and what the data presented / reported really means.
Hope that this helps - let me know if you need assistance
Alan Sharp
1 Files
53 Downloads
Attachment(s)
zip file
Mass Haul Training Program.7z.zip   1.60 MB   1 version
Uploaded - 11-18-2020
01-08-2019 12:34
Correct - the files will be upgraded to 5.0 on opening and then when you
save them you wont be able to go back to earlier versions - otherwise all
should be basically the same. If you need help on this at all please let me
know - Happy to provide guidance as necessary
On Tue, Jan 8, 2019 at 12:29 PM rstallings@dragados-usa.com <
01-08-2019 12:28
Hello Alan,
   I just downloaded the .zip to learn Mass Haul.  When I get the upgrade to TBC 5.0, this file should still work fairly seamlessly, correct?
Thanks
07-09-2018 07:04
I am uploading again - the first file failed for some reason
07-09-2018 05:33
Good day Alan
I just downloaded your zip file on mass haul & the zip file does not have files mentioned in your explanation of what is in the file. Maybe there is something I am missing please assist?
