View Entry
Trimble Penmap
Community Navigator
Back to Library
New Penmap for Windows version 10.8.6.8425
Recommend
11-20-2019 09:06
Cornelia Schmitz
We have released a new Penmap for Windows version today.
The version 10.8.6.8425 includes the following enhancements:
New features
Take over new feature and attribute setting if the GIS from the global template is changed. You can now update the template in
Settings
Template
Created an offline Map Tile Cache on the SD card with WMS Map Tiles for Penmap for Android (up from version 10.8.8) via the Android SD Card (
Workspace
MapPack
Use a geometry as border for WMS Map Tile Cache Creation, for example, to load only tiles inside an area to reduce the needed time and memory space (
Workspace
MapPack
Multi iFeature: New feature to collect 1 to n features (for example, gas and water) at the same time, which means you only need to measure one point.
Enhancements
Changed map provider address syntax from
http://
to
https://
Changed the Flemish RTK network FLEPOS caster address to
http://flepos.vlaanderen.be
Swipos connection changed from IP address 194.88.197.200 to www.swipos.ch.
Fixed the
Connect to
button, which is grayed out for GNSS correction via RTK service.
Fixed usage of caster address in URL format (please enter without "
http://
Source tables for GNSS correction data are received via "Internal Connection".
Enhanced Trimble Connect handling: Ignore Connect project if it is not readable.
Improved the automatic detection of the Trimble T10 internal GNSS COM port.
Penmap generated attributes for easting and northing are fixed.
AutoPerimeter can be used in the database editor for Penmap for Windows.
The AutoArea and AutoPerimeter GIS attributes now use the projection reduction in Penmap for Windows if it has been enabled.
Updated the coordSystemDatabase.xml file to version 87.
