The function generates a sports field and places it in the drawing.
MOUS_ICO Menu: Landscape > Construct Lines and Polygons Parametric Sport Field MOUS_ICO Toolbar: Construct Lines and Polygons: Parametric Sport Field
The function can create three types of sports fields:
Type in parameters for Width, Length, and Radius center in meters and press OK. Pick sports ground center point. Pick a point in the drawing Pick sports ground direction. Pick a point to define the rotation.
Sports areas can also be set out as an illustration from the symbol library.
