Novapoint Landscape Library
Pasteclip Point Elevations
04-08-2021 08:26
Use this tool to pasteclip point elevations and slopes to a new drawing that has been copied from another drawing by using the Copyclip point elevations function. Note that the AutoCAD-command pasteclip does not work on point elevations!
MOUS_ICO Menu: Landscape > Elevation tools - drawing> Pasteclip point elevations
MOUS_ICO Toolbar: Landscape II: Pasteclip point elevations
Working procedure
Start this function after the function Copyclip point elevations have been used in the drawing with the point elevations you want to copy to the current drawing. The command prompts:
Select new position or type world coordinates:
Choose a position for the copied elevation object(s) or type the world coordinates.
About point elevations in Novapoint Landscape
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
