Novapoint Landscape Library
Point Elevation from Triangle
04-07-2021 19:55
Use this tool to generate point elevations from triangles in a drawing.
MOUS_ICO Menu: Landscape > Levelling tools >Point elevation from triangle
Use triangles represented by 3D faces in dwg to calculate height and create point elevation. The visual style in the drawing must be of the type with shade in order to get point elevations with this function. (Use the command SHADE)
About point elevations in Novapoint Landscape
  • Point elevations are blocks with insertion points in the “+”-sign. The z-value for the block will always be equal to the written text.
  • It is possible to use osnap when setting out point elevations - the z-value in the specific point snapped to will show in the command prompt. To use the snapped z-value instead of typing in a value - just press enter!
