Novapoint Landscape Library
Point Elevations from 3D Poly...
04-07-2021 19:56
Use this tool to generate point elevations in the nodes of a 3D polyline.
MOUS_ICO Menu: Landscape > Elevation tools >Point elevations from 3D poly
MOUS_ICO Toolbar: > Elevation tools > Point elevations from 3D poly
Working procedure
  • Start the function.
  • Select the 3D polyline from which you want to generate point elevations.
About point elevations in Novapoint Landscape
  • Point elevations are blocks with insertion points in the “+”-sign. The z-value for the block will always be equal to the written text.
  • It is possible to use osnap when setting out point elevations - the z-value in the specific point snapped to will show in the command prompt. To use the snapped z-value instead of typing in a value - just press enter!
