Project Unit Settings
12-24-2020 10:01
Project administrators can adjust project settings to set project preferences. You can access the project settings on the Settings page in Trimble Connect for Browser.
Set the standard units to be used throughout the project. Trimble Connect has expanded unit settings for the project system and allows users to specify display precision on each unit e.g. Length, Area, Volume Angle and Measurements Length.
Unit setting support varies by application.
Supported Settings
Metric
Distance
Display Precision
mm
0, 0.1, 0.01, 0.001
cm
0, 0.1, 0.01, 0.001
m
0, 0.1, 0.01, 0.001
km
0, 0.1, 0.01, 0.001
Area
Display Precision
cm2
0, 0.1, 0.01, 0.001
m2
0, 0.1, 0.01, 0.001
km2
0, 0.1, 0.01, 0.001
Volume
Display Precision
cm3
0, 0.1, 0.01, 0.001
m3
0, 0.1, 0.01, 0.001
km3
0, 0.1, 0.01, 0.001
Weight
Display Precision
mg
0, 0.1, 0.01, 0.001
g
0, 0.1, 0.01, 0.001
kg
0, 0.1, 0.01, 0.001
t
0, 0.1, 0.01, 0.001
Angle
Display Precision
deg
0, 0.1, 0.01, 0.001
rad
0, 0.1, 0.01, 0.001
deg-min-sec
0, 0.1, 0.01, 0.001
Imperial
Distance
Display Precision
in
0, 0.1, 0.01, 0.001
ft-in
½, ¼, ⅛, 1/16 1/32 1/64
ft
0, 0.1, 0.01, 0.001
yd
0, 0.1, 0.01, 0.001
mi
0, 0.1, 0.01, 0.001
Area
Display Precision
in2
0, 0.1, 0.01, 0.001
ft2
0, 0.1, 0.01, 0.001
yd2
0, 0.1, 0.01, 0.001
Volume
Display Precision
in3
0, 0.1, 0.01, 0.001
ft3
0, 0.1, 0.01, 0.001
yd3
0, 0.1, 0.01, 0.001
Weight
Display Precision
oz
0, 0.1, 0.01, 0.001
lb
0, 0.1, 0.01, 0.001
ton
0, 0.1, 0.01, 0.001
Angle
Display Precision
deg
0, 0.1, 0.01, 0.001
rad
0, 0.1, 0.01, 0.001
deg-min-sec
0, 0.1, 0.01, 0.001
U.S. Survey
Distance
Display Precision
sIN
0, 0.1, 0.01, 0.001
sFT
0, 0.1, 0.01, 0.001
sYD
0, 0.1, 0.01, 0.001
sMI
0, 0.1, 0.01, 0.001
Area
Display Precision
in2
0, 0.1, 0.01, 0.001
ft2
0, 0.1, 0.01, 0.001
yd2
0, 0.1, 0.01, 0.001
Volume
Display Precision
in3
0, 0.1, 0.01, 0.001
ft3
0, 0.1, 0.01, 0.001
yd3
0, 0.1, 0.01, 0.001
Weight
Display Precision
oz
0, 0.1, 0.01, 0.001
lb
0, 0.1, 0.01, 0.001
ton
0, 0.1, 0.01, 0.001
Angle
Display Precision
deg
0, 0.1, 0.01, 0.001
rad
0, 0.1, 0.01, 0.001
deg-min-sec
0, 0.1, 0.01, 0.001
Notes
Each user in the project can chose their own display units. (They are not shared throughout the project.
If you select Custom for the Unit System, you will be able to combine units from both Imperial, U.S. Survey and Metric systems.
In order for properties displayed in the 3D Viewer to be converted to the specified unit setting - the correct IFC Property Type must be used:
  • IfcLengthMeasure - Length
  • IfcAreaMeasure - Area
  • IfcVolumeMeasure - Volume
  • IfcMassMeasure - Weight
  • IfcPlaneAngleMeasure - Angle
