This tool removes the description on lines that were drawn with the !!linetype library!!. The function allows us to remove the quantity on lines while keeping the ability to act as borders when creating land use areas when using the function Land Use Disposal or be included in the Quantities.
MOUS_ICO Menu: Landscape > Lines>Remove properties from lineMOUS_ICO Toolbar: Lines> Remove properties from line
When the function is run, you are prompted to select the lines to be purged. All AutoCAD XDATA will be removed from these lines.
