Novapoint Landscape Library
Reset Point Elevations
04-08-2021 08:27
This tool will reset positions for text, attributes, or “+” within a point elevation object.
MOUS_ICO Menu: Landscape > Elevation tools - drawing > Reset point elevations
MOUS_ICO Toolbar: Landscape II >Reset point elevations
Working procedure
Start the function and the command prompts:
Select point elevations to update:
Select the point elevation object(s) that are to be reset. When finished, press 'Enter.' The selected point elevations will be removed and set out again refreshed. Any manually changed positions regarding the text or underline will be lost.
About point elevations in Novapoint Terrain
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
