Novapoint Landscape Library
Slope Restrictions
04-07-2021 19:58
Use this tool to set maximum and minimum slope values and get “faulty” slopes highlighted.
MOUS_ICO Menu: Landscape > Elevation tools >Slope restrictions…
MOUS_ICO Toolbar: Elevation tools –  Slope restrictions…
Working procedure
Start the function. The 'Slope restriction' dialogue appears:
Type maximum and minimum slope values. Press Activate - all slopes in the drawing who does not match the entered interval will be indicated in the drawing by colour magenta. They will maintain indicated as long as they are not edited into “correct” slope interval or until the function is deactivated by pressing the button Deactivate. The dialogue can be closed whether the function is activated or deactivated.
About point elevations in Novapoint Landscape
  • Point elevations are blocks with insertion point in the “+”-sign. The z-value for the block will always be equal to the written text.
  • The levelling tools are a set of functions working within the dwg file as well as interacting with active terrain model. Editing and calculating point elevations must be done by using the levelling tools only! It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearence of point elevations in Novapoint Landscape
