TBC Help - Terramodel Equivalents
07-05-2021 19:02
This older document is being posted at the request of a few TBC users.
Use this chart to see which commands in Business Center - HCE replace the ones you used in Terramodel. To find any command in TBC, select the appropriate ribbon tab, or press F12 to display the Command Pane, which lists all of the commands in the program.
Disclaimer: This information was last updated in December 2017 for Business Center - Heavy Construction Edition (BC-HCE). In many cases, it will not match the current version of Trimble Business Center.
1 Files
39 Downloads
Attachment(s)
pdf file
TBC Help - Terramodel Equivalents.pdf   218 KB   1 version
Uploaded - 07-05-2021
