Novapoint Landscape Library
Terrace Height
04-08-2021 08:33
Use this tool to set a box to point elevation.
MOUS_ICO Menu: Landscape > Elevation tools - drawing> Terrace height
MOUS_ICO Toolbar: Landscape II: Terrace height
Working procedure
Start the function and the command prompts:
Select object:
Select the point elevation object(s) that are to get a box. When finish, press 'Enter' and the selected point elevation objects will get a box.
About point elevations in Novapoint Landscape
  • The leveling tools are a set of functions working within the dwg file as well as interacting with the active terrain model. Editing and calculating point elevations must be done by using the leveling tools only. It does not work to use AutoCAD-functions like move, copy, copyclip/paste, properties, attribute editor, etc. in order to edit or manage the appearance of the point elevations
