This command lets you update the shape of land use areas to fit the borders automatically (based on topology), and also refresh the attributes. Use the command when you have changed the borderlines of a Land Use area and want to fit the hatch again.
MOUS_ICO Menu: Landscape > Land use disposal > Update Connection with Borders, AutomaticallyMOUS_ICO Toolbar: Land use disposal: Update Connection with Borders, Automatically
When the command starts the dialog 'Set Active Plan' is shown - press OK. (This defines the drawing rules for the plan, use 'Landscape Design plan version 16.30/17.10 with color' according to the NP version you are using.
Select objects: Pick the areas to be updated, or type 'all' in the command line to update all the areas. Press enter and all areas are redrawn to fit their borders.
Select objects:
