Novapoint Landscape Library
Update Connection with Borders, Manually
04-08-2021 08:58
This function lets you edit and update the properties and borders of an existing Land Use Area manually.
MOUS_ICO Menu: Landscape > Land use disposal >  Update Connection with Borders, Manually
MOUS_ICO Toolbar: Land use disposal:  Update Connection with, Borders Manually
Use this function if the shape (borderlines) of the area has changed and you want to pick the lines manually, or the attributes or drawing rules of the Land use Area have been edited. (If you want to update automatically based on topology use the function: Update connection with borders, automatically).
When the function is started you get the following sequence in the command line:
Select Area: Click the hatch or leader text in the area.
The dialog 'Establish Land Use in Drawing' appears. Depending on how you want to define the borderlines use one of the buttons:
  • 'Pick point<' Define a new surface: Pick a surface representation point inside the area/Enter to Cancel : Click in an area confined by the borderlines.
  • 'Select Polygon<' Pick a line,arc,polyline:Pick one ore more lines to define the border and press 'Enter', you will see a preview in magenta color.
Pick lines creating a hole inside the area: Press 'enter' to proceed (or select polygons and lines to define holes (press enter between each hole) and press 'Enter' to end.)
The area is updated.
