I don't know if it's a TBC or Siteworks issue, or a limitation of the .PRO format (after all it's a Terramodel file format).
I've got a surface that's compiled from triangle data, some alignments and I try to create a job site design as "road surface" from it.
If I add all my data to the surface I don't get the fishbone/triangles on one specific alignment when I load the project in Siteworks (latest version).
That alignment then won't show offset/chainage/cross sections.
It should look like that.
After lots and lots of iterations I found that removing triangles far away from the start/end of that specific alignment makes it suddenly work.
Why would that happen???
