 Break a line at a 3D intersection.
Sam Lemon's profile image
Sam Lemon posted 03-05-2021 10:04
Hello
I'm trying to create some river cross sections in TBC.
To generate the water level I want to create a narrow surface at a set elevation however I don't want this surface to extend beyond the river banks.
This exercise has highlighted in interesting issue, I cannot break the blue line at the 3D intersection with the brown line. Clip, break and trim only work at the lines vertices points, how can I create a vertex at this 3D position?
Any ideas on how this can be achieved?
Many Thanks
Sam
Marian Plucinski's profile image
Marian Plucinski
1) Create Surface for water level
2) Create Surface for river banks
3) Surfaces -> Surface Intersect Lines
Marian Plucinski
2nd option would be to use Trimble's Slope - Slope macro:
Alan Sharp's profile image
Alan Sharp
The challenge with this in TBC standard is that the two lines are colinear - ie they occupy the same space and TBC works primarily in 2D to determine when two lines intersect. To create the intersection point of two colinear lines requires a dedicated command to achieve that. What you can do however is the following
1) Select line 1. Right click and open the Profile Viewer for that line.
2) Select line 2 and then hold the shift key down while you select Profile Viewer for Line 2
This will open the second lines profile in the same viewer as line 1. You can clearly see the intersection of the two lines- you can exaggerate the profile view and then you can break the line at the intersection of the two profiles or add a VPI. Note you have to edit the Line used to initiate the Profile view not the second line that is a proxy in the profile view. It will be pretty accurate - you can zoom right in and typically select to a mm or better.
A dedicated command could be created to do this if needed I am sure, however when you start implementing Vertical Curves in the lines it might not be so easy.
