 TBC Install Error - Unable to load DLL "SDE_API_x64.dll"
Tylor Foster's profile image
Tylor Foster posted 02-25-2021 23:35
I was trying to update from 5.34 to 5.4 and this happened after the install. I have tried repairing, reinstalling, deleting programs and re-installing. I can't get past this block.
Any help?
Alan Sharp's profile image
Alan Sharp
The issue is caused by some files on your windows system being missing - you can fix it by doing the following
This error has popped up a few times with users installing TBC v5.40.
The issue is caused by a missing DLL file in the Windows System 32 folder.
The fix is to download and install the .exe files found in the link below
Click Here 5 for the link
More detail is provided at the above link. Download and install the files
vc_redist.x86.exe
vc_redist.x64.exe
For some PC’s the x64 version alone fixed the problem, on other computers they have had tio run both files to cure the issue.
