When building a corridor, how can I avoid the triangels from binding across each others when the alignment is turning? For example if i type in elevation/slope up to a height the top line is not smooth like I want it. It´s making loops and crosses itself
  • 1.  When building a corridor, how can I avoid the triangels from binding across each others when the alignment is turning? For example if i type in elevation/slope up to a height the top line is not smooth like I want it. It´s making loops and crosses itself
    Posted 06-20-2018 23:32
  • 2.  Re: When building a corridor, how can I avoid the triangels from binding across each others when the alignment is turning? For example if i type in elevation/slope up to a height the top line is not smooth like I want it. It´s making loops and crosses its
    Posted 06-21-2018 07:02
    Magnus
    It looks like the source alignment that you are using for your "corridor" is not curvilinear i.e. it has angle bends in it. These will not work well with Corridor command unless you can put small radius arcs in the angle bends that are causing you the crossover issues. In that type of line where I am trying to project a slope I would always use the Create Surface Tie command as that handles angular corners like those shown in your picture. If you need to include the Tie slope into a corridor it can be added to the Corridor Surface using Add / Remove Surface Members to fulfill the needs of the sideslope.
    I will record a short video and post it this am to demonstrate this
    I also posted this question on the BC-HCE forum - because that is where I work mostly and for the benefit of BC-HCE users I thought it worth duplicating there. I have a separate response there also because I didnt have your picture when I wrote that this am
    Hope this helps
  • 3.  Re: When building a corridor, how can I avoid the triangels from binding across each others when the alignment is turning? For example if i type in elevation/slope up to a height the top line is not smooth like I want it. It´s making loops and crosses its
    Posted 06-21-2018 08:37
    Looking at your specific problem Magnus now that I have tried it, because you aren't creating a Tie slope, just a Slope to an Elevation (I think that is what you have used right?) this is likely the best solution to your problem -I have posted a video of the issue and solution.
    Depending on the angularity of the line and the offset that you will be creating for the element, you may find that if you Fillet Curves into the angular joins of the source alignment of eg 20m radius that you can mitigate some of the "cross overs" however with larger offsets the crossovers will still be present. Below I have captured what I would do to solve your issue
    Use the corridor as you have done it to create the Surface Element that you have created. You will need to Explode the Corridor Surface to turn it into Linework and then you will need to break the lines around the locations where you have crossovers and find the "True Surface Point" which is where the Inbound and Outbound lines at each crossover cross each other. Delete out the segments that you don't need and then join the line back together again. You can then edit your corridor template, and remove the slope element from the template. Now you can use Add / Remove surface members to add the 3D line that you just edited / created into the Corridor Surface Model. I recommend also adding the 2 end lines of the corridor surface that you exploded to close out the boundary around the slope that you created.
    The attached video shows the process in more detail with a worked example
    Hope that this helps - let us know how you get on
    Thanks for the question
  • 4.  Re: When building a corridor, how can I avoid the triangels from binding across each others when the alignment is turning? For example if i type in elevation/slope up to a height the top line is not smooth like I want it. It´s making loops and crosses its
    Posted 07-05-2018 23:12
    Thanks for answering! That's the way I got past the problem to.
