Editing linestrings
  • 1.  Editing linestrings
    Posted 02-13-2020 03:08
    Hej!
    I have a suggestion for the editing linestring-command. It would be nice to be able to continue adding horizontal segments between existing segments when you click the "Insert before current segment"-button. Like it is with the "Add after last segment"-button. For example, if I want to add say 20 segments between two existing segments I now have to click the add-button - draw the segment - click add - draw - and so on. Or cut the line, redraw it and then reconnect it. It would be easier to just click "insert before current segment" - draw all the segments I want - unclick the button and be done. This would be time-saving.
    /Magnus
    Horizontal segments
  • 2.  Re: Editing linestrings
    Posted 02-13-2020 08:26
    Agreed. This is a pain when modifying things like boundaries.
  • 3.  Re: Editing linestrings
    Posted 02-13-2020 15:01
    If you use the insert line segment macro this does what you are asking in a simple and easy way. It will draw segments between any segment with a single click. I agree that the edit linestring could be easier
  • 4.  Re: Editing linestrings
    Posted 02-17-2020 02:06
    Thank you, Alan! That pretty much does it!
    But it would still be nice to have it integrated in the edit linestring-command
  • 5.  Re: Editing linestrings
    Posted 02-13-2020 23:26
    Here is a video of the Insert Segment Macro and the Quick Line Macro which I use all the time for editing Linestrings
    Seems like the Upload Video function is not working - I will post it somewhere you can find the video and place a link
    Click Here
