Michael
IFC solids and DWG / DGN Solids get imported into TBC as IFC Shell objects. If you have the TML Status command installed, make sure that you download and install all updates to all of the extension command library that is available.
The Explode IFC Shell command explodes the solids into 3D linework. If for example the IFC Shell represents a 3D Pavement surface - it will have a thickness, a Top, a Bottom and likely Vertical Sides. The faces of an IFC Shell object all have a defined "Normal" (a line perpendicular to the face that defines the "outside face" or an "Inside face" (like the inside of a pipe) etc. In the explode process you can elect to explode all faces or you can Select Normal Up or Normal Down etc. and this typically equates to the Top side and the bottom side of a surface layer like pavement etc.
If the IFC is defined correctly (which some have the Up and Down wrong (even in a single file from some vendors) then you may have to do Normal Up first and then Normal Down second if the first approach doesn't work.
This creates a set of 3D linework of all of the faces in the solids that were exploded. You can explode different parts onto different layers in TBC to separate the Tops from the Bottoms etc. That linework can be turned into TBC Surface Models using the Create Surface command. That surface can be used for volumes as needed.
If you need to find the breaklines in the surface model (so you can apply subgrade adjustments etc. then you can use the Explode Surface command to find breaklines in the model that you just created - this will generate breaklines that meet your "Break Angle" criteria defined in the Explode Surface Command
If you are working on a linear project or linear data set where you have a lot of features running near parallel or sections running near perpendicular to a line / alignment then you can use the Filter Line Vertices command to select triangle sides from an exploded surface or IFC Shell object that follow linear features - this is a handy tool when working on Road, Rail or Pipeline type projects.
All of the above commands are documented and video documented - when running the command Press F1 to get to the help pages for the extension commands.
If you need help with any of this please email me at alan.sharp@rockpilesolutions.com and send me your phone number and I will happily connect with you to show what is possible.
