Is any one else having issues exporting RXLs from TBC v.5.3? I keep getting the same error message. I have tried it on several computers with no success. It works fine on older versions though.
Hi Nicolas,
Have you set a proper "horizontal alignment station interval" in the Export pane? By default the number is 0, but you need to change it to a non-zero value (i.e., 5m, or 10sft) so TBC can do the sampling.
Hi Rui,
That was indeed the problem and it's fixed now. Thanks for the answer.
