Has anybody ever encountered this error whilst trying to post process a PPK survey using the VRS Virtual Base Point Download. I am recently new to TBC. The survey was completed using Trimble R10 if that helps?
Thanks in advance.
Hi Colin,
Would you mind sharing your dataset so we can take a closer look? Thank you.
Hi Rui Wu,
No problem, link to dataset attached.
Dropbox - Raw Survey Data - Simplify your life
Thanks,
Colin
Thank you for the raw data. Which base point were you trying to download? The closest physical base station I can find from our list is 26km away.
