Generate a Chainage Offset Elevation report of only my staked points
  • 1.  Generate a Chainage Offset Elevation report of only my staked points
    Posted 08-28-2020 17:12
    I'm trying to export a Chainage Offset Elevation Report to Excel of some points that I've staked from a corridor. When I generate the report, it's giving me a pair of points, the one I staked, and the corresponding point for that chainage on the alignment. Is there anyway to generate this report without that alignment point being added as well?
  • 2.  Re: Generate a Chainage Offset Elevation report of only my staked points
    Posted 08-30-2020 06:57
    Turn off the HAL points and leave only points from setting out. But again in Excel you can just sort through code or name and erase all the extra.
