Labels at random Chainages on Alignment
  • 1.  Labels at random Chainages on Alignment
    Posted 10-15-2020 11:45
    Is there anyway to create labels (text) at random Chainages along an Alignment,
    I've got a Railway CL about 20km long and an Excel Spreadsheet of about 20 points where Overhead Power lines cross this alignment,
    I want to create "Ticks" at these Chainages and to label  them - this is the part I can't see easily how to do (use to be easy in Terramodel)
    then export to DXF so I can go into the field to survey / check the overhead line clearance
    Thanks
    John
  • 2.  Re: Labels at random Chainages on Alignment
    Posted 10-15-2020 12:04
    Found a solution
    Under Data Prep Macro,
    Sta/Offset Points
    Create Points
    Then label those points
  • 3.  Re: Labels at random Chainages on Alignment
    Posted 10-15-2020 15:38
    That works John - we are just wrapping up an XLINES command for this exact purpose - should be out in the next week or so.
  • 4.  Re: Labels at random Chainages on Alignment
    Posted 11-16-2020 18:16
    Hi Alan,
    What progress with the XLINES Labelling command above?
  • 5.  Re: Labels at random Chainages on Alignment
    Posted 11-16-2020 18:43
    It will release this week
    Making progress on your label points also
    On Mon, Nov 16, 2020, 6:17 PM john.mill@mcdgroup.com <trimble@jiveon.com>
  • 6.  Re: Labels at random Chainages on Alignment
    Posted 11-16-2020 19:09
    Did you want to try out the Xlines and Label commands - I can set them live
    for you and give you a trial license if you would like to
  • 7.  Re: Labels at random Chainages on Alignment
    Posted 11-16-2020 20:14
    Yes please
    That would be good – I’m labelling up areas of As Built Services for Dig Permits
