Mirror elevation not working with point labels? (depths)
  • 1.  Mirror elevation not working with point labels? (depths)
    Posted 09-10-2020 15:10
    Hi everyone
    Has anyone else found that the 'mirror elevation' function is not being applied to point labels?
    I'm wanting to display depths so we use mirror elevation to display the negative elevations as positive depths.
    This works fine until you try to label the points and it then displays the elevation with a negative sign instead of positive.
    Cheers
    Bevan
  • 2.  Re: Mirror elevation not working with point labels? (depths)
    Posted 09-12-2020 16:59
    I can see what you are seeing Bevan and will report it in or see if I am missing something on Monday - I have a feeling that there is some Hydro Setting somewhere that you need to activate to get what you are looking for but I cannot for the life of me find where that might be - you may also be looking at a defect - I will let you know this week.
  • 3.  Re: Mirror elevation not working with point labels? (depths)
    Posted 09-13-2020 13:30
    Great, thanks Alan.
  • 4.  Re: Mirror elevation not working with point labels? (depths)
    Posted 09-15-2020 11:14
    Seems that this is a defect - I have logged it in Bevan. Sorry I have no answer quickly here.
    I can likely create you a Point Label routine that takes care of this and the Hydro Nomenclature if you need it - just let me know
