Hi Rui,
Please see images below.
I have also been discussing this with our Trimble supplier here in Ireland they have come up with two solutions:
"We’ve been looking into this for you and have found a quick fix.
When carrying out your survey in the field, to stop the curve line from transitioning from or into a straight line, the fastest way is to simply record an observation on the point at the start of the curve (with no CS suffix) and then record a second point on top of that same point (with the CS Suffix).
The issue is that for extreme curves, TBC is trying to transition the linework smoothly.
The Break Line Function in the CAD Toolbar I mentioned in a previous email will work also."
This would mean recording multiple two points at each curve start, this issue i'm having isn't at every curve start just some...
