Can we change surface viewing defaults?
  • 1.  Can we change surface viewing defaults?
    Posted 10-07-2020 10:25
     Every time we make a surface we change all of the view properties to "no" (e.g. wireframe, breaklines, drapelines, etc.) and leave only the shading on. I'd imagine other users do the same for the most part. If it doesn't seem prudent to universally change the defaults, could we at least have an option to set these globally in the project settings?
  • 2.  Re: Can we change surface viewing defaults?
    Posted 10-07-2020 14:06
    I agree Devin - this has been requested and is on the Trimble list.
    I will see what can be done about that
  • 3.  Re: Can we change surface viewing defaults?
    Posted 10-09-2020 04:21
    Surfaces made by Take-off have other properties then surface made from the menu create surface or by corridor, so it should be possible to change the defalut parameters. It would safe us a lot of time.
