Karen
If you want to reverse the direction of an instruction, create a short
offset elevation instruction before the one you are trying to create that
goes the direction you want to go in ie Offset -0.01, Elevation 0 as the
prior node determines the direction of the slope. When you have a Slope
Elevation command it has no direction other than Up or Down so the prior
node dictates the direction - if the prior node is going Right then the
slope goes right,if the prior node goes left then the slope goes left etc.
The prior node can be an Offset Elevation or an Offset Slope instruction if
you are concerned about a 0 elev diff over 0.01' distance.
On Sat, Apr 25, 2020 at 10:02 PM kdeguzman@landmark-sc.com <
