Feature Request - Angle in Corridor Slope\Elevation Instruction
  • 1.  Feature Request - Angle in Corridor Slope\Elevation Instruction
    Posted 10-25-2018 12:29
    I would like to be able to to Angle in the instructions under corridor modeling. I'm trying to do an angle off a known location. Rather then try to figure out the slope it would be nice to be bale to to put the desired angle in. I need to do angle of the face of the wall @ 6 degrees. See below for reference. If there is a way to do this I have not been able to figure it out. I've just done my calculations manually to figre out the percentage.
    Thanks
  • 2.  Re: Feature Request - Angle in Corridor Slope\Elevation Instruction
    Posted 10-26-2018 06:57
    Erik
    You can enter Vertical Angles into Slope fields already - look at your Units Settings under Project Settings to see what your Vertical Angle Settings are (Most likely set to Zenith Angles). That being the case a Slope can be entered in as z6 , z 6 or Z 6 00 00.00 for 6 degrees. If you need minutes and seconds then the format is z000 00 00.00.
    Another great day for modeling
  • 3.  Re: Feature Request - Angle in Corridor Slope\Elevation Instruction
    Posted 10-26-2018 07:15
    I should have looked at the help file before submitting that! Thanks
