No more auto populate boxes in 5.3
  • 1.  No more auto populate boxes in 5.3
    Posted 05-08-2020 08:33
    It will not longer auto populate in 5.3. Say I want to break a line at a crossing line
    Before it would auto populate the crossing line box and I just have to click the line I want it to break at. Now I have to tab to get to that box or click on it. This is greatly affecting my workflow and had to go back to 5.2. It's also doing it in other areas. See below
    Cursor starts in wrong box.. Have to tab to do anything...
  • 2.  Re: No more auto populate boxes in 5.3
    Posted 05-09-2020 06:21
    I agree … it has drastically affected my work flow as well.
  • 3.  Re: No more auto populate boxes in 5.3
    Posted 05-09-2020 09:09
    I had noticed this and thought it was just me as I have not been doing much production work the last 3 weeks or so - have raised the flag and will push for an answer this week
  • 4.  Re: No more auto populate boxes in 5.3
    Posted 05-11-2020 12:50
    I have recreated this in this one instance - is it anywhere where that Station at crossing line is used or is it in other Snap Controls as well - do you know - I have logged it in  and it only seemed to affect that one control in those Right Click options for that distance along control. Are you seeing it in other Right Click snaps also?
  • 5.  Re: No more auto populate boxes in 5.3
    Posted 05-11-2020 14:19
    When I also try adding a VPI to a crossing line it makes it populated to the top "Line:" command instead popping back down to Distance along , where I can tab once to elevation, right click, along line snap, at crossing line. . Where its currently at I'm having to either physically click elevation or tab, eight times, to get there. Let me know if I need to make a video to explain it.
  • 6.  Re: No more auto populate boxes in 5.3
    Posted 05-11-2020 14:59
    It is a general issue that the Right Click Snaps are not returning to the
    Next position field - they are returning to the command start point which
    is wrong - I have put the request in to address this overall
  • 7.  Re: No more auto populate boxes in 5.3
    Posted 05-11-2020 15:43
    Gracias!
  • 8.  Re: No more auto populate boxes in 5.3
    Posted 06-10-2020 04:50
    this is a major bug and needs to be addressed sooner than later.
